Hey guys
So recently my dc2r was struggling to start when the engine is fully cold. Although it struggled it would eventually turn over and start. When it was warm it would start easily from then on, until I leave it to fully cool down. Also I should mention that once the car is warm and i've been driving for a while at times mainly in the lower gears and below 2000rpm, the car would sputter/misfire.
As a maintenance precaution I changed out my ignition leads to NGK knowing that i needed new ones anyways. This didn't help, car still struggled to start. Then i changed out the spark plugs to NGK irdiums and still no help. Last I replaced a whole new distributor and this is when the problem occurred, now it wont start at all.
I marked the position of the distributor before taking it out and made sure to line up the new one exactly. I checked that all my ignition leads were reconnected in the right order
3 4
1 2
I checked all ignition coils and there are sparks coming from each, which means the distributor is working (I even removed the distributor to make sure I installed it correctly and in the right way). I checked the battery and its perfectly fine.
When I say it wont start, I mean the engine doesn't even crank i just hear what sounds like a buzzing sound which seems to be the starter motor. It seems that the starter motor cant turn the engine.
I've been doing some reading and I know some suggested that it could be the timing since the distributor may have moved....but even if it moved slightly the car should still start it might just be rough right?
Have any of you guys experienced anything similar?
any help or input would be much appreciated
Thanks
3 4
1 2
Thanks
