SRS Airbag Light ON
    SRS Airbag Light ON
    Hey All,
    I recently pulled my SRS Airbag fuse (#13) out to for a quick test and plugged it back in and now my airbag light is on =/
    pulled it out again and checked the fuse and its all good.
    Am i going to have to go back to Honda for a resolution for this?
    Thanks.
    Have you tested the fuse with a volt meter? Or did you just do a visual check? Have you tried disconnecting the battery for awhile to allow the cars ECU to reset?
      battery hasnt been disconnected.
      didnt test the fuse =) maybe i should, visually its good
        yeh, do the battery reset and see...
          what if i have an aftermarket ecu, will battery reset, reset the ecu?>
            What ECU? If KPro it will not.
              ktune
