Hi guys,
Probably a long shot to get an answer but I'm trying to fix an exhaust leak. Replaced the mugen cat with a magna flow cat because the mugen cat had a crack in the body.
However, I also need to replace the gasket which I'm not sure where to get. As far as I gathered, the collector is 60.5mm.
Will any generic donut gasket 60.5mm ID size do the job? I'm not sure if i need a specific OD size.
Thanks
Thanks
