Ok all i thought i would start a thread in relation to the new project i am going to build. I bought the EG Hatch last week for 2k, EG Si with JDM B16A conversion, it had some minor panel damage and front drivers side sussy was bent but all is fixed now.
PICS
Exterior
Interior
Ok so the plan is to in the near future put a K swap in the car, at this stage i am unsure if it will be a k20 or k24/20 combo. The car is going to be setup for circuit racing and Centrax are going to be supplying quite a lot of the parts
and possibly doing the swap for me.
In terms of the swap, i'm aware i will need the following parts:
Hasport EGK1 Bolt In Mount Kit (This Kit)
K20A Intermediate Shaft
Hasport EGKAX Axle Set
K20A or K24 Motor and *Compatible Transmission
Hasport EGWK Conversion Harness
K-Series ECU with Immobilizer removed (will keep my current k-pro)
RSX Shifter Box & Cables
Throttle Cable that matches your engine
Custom Header, Exhaust & Catalytic Converter
K20 After-market Fuel Rail With Return Line Option & Regulator or External Fuel Pressure Regulator with return port and stock fuel rail
RSX Brake Booster Hose
2002 RSX Radiator Hoses
Other parts
Aftermarket Header
3" Zorst
Half Cage
Seats - Recaro or BuddyClub
Zeal Function X's Coils
Endless 262mm disk with 4 pot caliper.
Struts and Sways
Buddy Club QF's 15"x7 with hoosier street legal slicks
Is there anything else i might need?
Is there any chance i could use my koyo radiator from my dc5?
I'll continue to update this as it progresses, should be getting painted in the next week or 2.
PICS
Exterior
Interior
Other parts
Aftermarket Header
3" Zorst
Half Cage
Struts and Sways
