Hi everyone out there with the same love for integras first i wana Race in Paradise O conner and his friend!
But alright i just made an account with citr' last night i need help if anyone can guve me sum info it will e much apreciated thanks, so i was drivin and i pulled up to my friends house when i did i left the car on about a minute at the most but while i did i heard sumtin hittin and figured out it was my timing belt ripping so i took off home before it finished rippin i got to the corner of my house an it turned off so i figured da belt ripped so i pushed it home, i got it fixed (Supposively) at a ''SHOP'' dey changed my belt the crank pulley nd sum sensor i forgot the name of it but before i forget when the car was running the check engine light came on as soon as i started hearing da little belt hittin inside da plastic dat cover da timing belt so i figured it wuld come off when they fixed it at the shop but it didnt, so what i did was use the 'No OBDll' way of gettin engine codes since my obdll plug doesnt wana read the obdll machine:/ so i used the other way and it gave me the codes: ( 80, 81, 82, & 83 )
I wana figure out what they are:/ if anyone knws it will do much help
The other problem is when supposively they replaced da belt nd pulley i drove it home and noticed dat when i let go of the clutch on first gear it shivered as if it was guna turn off but then caught on i was like? Wtf.. I dont knw if they left a teeth off from da belt like maybe dey disnt leave it on point or if i have to do anytin to the computer to tune it to the belts timing or what? But what idid do and it helped a bit is , i messed around with the distributor cap moved it around to where i saw it wasnt shiverin much it helped a liddo it doesnt seem as lazy when i let go of the clutch and start drivin but i knw sumthing is wronge regardless so i tought maybe sum one can help its very apreciated im only 20 not much experienced with the whole car mechanic stuff:/ thanks for the help if anyone can give sum info thank you
