Hey guys,
Background: I changed the clutch, flywheel, rear main seal back in June 2011 when the car was around 100,000km. The clutch was an Exedy racing stage 1 heavy duty clutch with an Exedy lightened Forged Chromoly Flywheel. I have tracked the car about 6 times since 2011, but I have always changed the oils/filters whatever right after.
Right now the gears are harder to put in, and it crunches at times when putting it in. I went to my mechanic who installed it and another mechanic; both said that I need to take the box out again, to find out whats the problem. When opening the gearbox inspection plate, they both said that the pressure plate or flywheel (can't recall what he said) looks hammered. One mechanic said that maybe its my "pressure plate, fork or pivot" that is playing up.
I was wondering what could be the problem as I don't want to take the gearbox out again once they install it all. I have also bled the clutch fluid and changed the gearbox fluid, and the problem still exist.
My mechanic said that I need:
-Clutch Kit
-Replace the rear main seal again
-New Flywheel? Can a lightened flywheel be machined? I dont want to buy a new one...
-Fork and Pivot? Where can I buy this from?
-Spigot bearing? Is this the same as a 'release bearing' that you get in a clutch kit?
If anyone can help, it would be appreciated. Thanks!!
-Clutch Kit
