VTEC Oil Pressure Switch - P1259
    Hi all,
    During an OBD2 scan of my ECU I picked up P1259 for the VTEC Oil Pressure Switch.
    On the vehicle, I'm unable to locate Part N in this link (http://i121.photobucket.com/albums/o...09_cr_rs33.jpg). It appears to be blocked off by a 12mm bolt. My understanding is that the JDM K20A didn't have this switch, but I am certain I have an A2. Perhaps the previous owner had the sensor fail and blocked it off?
    Would anyone understand why this might be the case? I will look into it further tonight to see if there is a spare harness wiring dangling in my engine bay. It seems very peculiar that this is blocked off.
    Cheers
    Ke
    Winton: DC5R - RE001 - 1.45.9
    AUDM K20A2s don't have the VTEC oil pressure switch either. Nothing to worry about.
      As Tom has said, if you are certain you have a K20A2 it's nothing to worry about since you don't have it at all.
      Do you happen to have a k-pro with your car? Because if you do and if it really annoys you, it is possible to turn off that sensor in k-pro.
      Either way it doesn't really matter anyhow, because I have a k20z1 with a k20a2 harness so I didn't have the plug for the switch on the harness even though I have the socket in the engine. I simply just switched it off in k-pro and It was all good. No dramas either.
      www.gundamuniverse.com.au
        Justin and Tom, cheers for the reply! I had done some reading and thought the lack of switch was only unique to the JDM K20A (according to CRSX)
        I guess that clears some air.
          No worries! Glad to relieve you some stress
