will the whiteline 22mm fromt sway bar clear the exhaust??? im currently running no front sway atm == and wondering if the 22mm white line front sway will clear the exhaust? i got toda headers on and a greddy exhaust system atm.
DC5R Question. Will Whiteline sway bar clear TODA header?
This topic is closed.
Originally posted by tuannn View PostThat's correct. I'm currently running a white line front sway bar with TODA Headers. Clears no problem at all.Originally posted by Stephen_AUS View PostWhiteline WILL CLEAR! I had one and it clears all aftermarket and JDM headers.Originally posted by felixR View PostRenamed the title for future reference.Originally posted by knobosaurus View PostIf you want your dc5r to handle like a performance car you'll get an aftermarket front sway bar. Running no sway bar probably negates the effect of the exhaust. Whiteline should clearthanks guys!!! feel much more relieved now! i was stressingOriginally posted by Batchy View PostI know for toda headers the only sway bar is the ep3 one that will fit. Its what I had to do with mine.
dont wanna drive around without a front sway and wear out my bushings ==
~146.4kw~
