Hey guys, I'm planning to buy some wheel spacers and just wondering if there are any disadvantages for them. Will any 5x114.3 spacers fit a dc5?
Wheel Spacers
As penut saidm only use repitable brand lile h and r.
U will need 5x114.3 / 1.50mm thread. And if they are decent quality like h&r they will habe correct sizing for hub which is 64.1mm for hondas.
H and r have two options. They will gove you either the hub centric bolt on for either 20/25mm or wider spacr set ups. However smallernthe spacer setup i believe up the 15mm h and r will provide you with h and r extended studs and a floating spacer with correct sized hub. If u go down the spacer route. Opt for hub centric bolt on. Two reasons why... fatter stance. And much cheaper as if u press in the extended studs. If u are doing it right u wannaget installed new oem bearings top which are exxy..
I will be buying second hand spacers. They are these ones
http://images.monstermarketplace.com...xd-600x400.jpg
I've been researching a bit and found out that spacers are quite dangerous and wheel adapters would be the better choice. Opinions?
Might just be me. But i wouldnt use spacers. very unsafe!
If your going to use them at least increase the stud length. You want atleast the width of the stud of tread protruding to bolt to!sigpic
Originally posted by stienerv2 View PostNothing wrong with ichiba wheel spacers. I've used them for awhile and sold them to Ryan. We never had any issues with them.
I was using 15mm spacers with 64.1mm bore. Perfect for the Hondas
