Changing to 5 stud
    Changing to 5 stud
    Hi all,
    I've had a search around and don't think there is much info on this:
    If you want to change from 4 to 5 stud, what parts are actually different? Can you just buy the hub or do you need a different steering knuckle too?
    I ask because most conversions include the knuckle and trailing arms, but are they even different from the ones on the 4 stud?
    If it was just the hub, could you not buy it new from Honda?
    Look forward to your thoughts, thanks.
    My question to you is why you doing the change.
    If your mainly doing the change to run Dc2R brakes. why not rethink. Buy the Prelude VTIRs rotor / calipers. Redill the rotor to 4 spoke and the caliper is a direct bolt on!
      I want to run 5x114.3 wheels, as well as changing the brakes to aftermarket.
        Do it 5x114 wheels are so much easier to find and tend to be cheaper in price
          5x114.3 is just FTW
