DC5R Engine Leak
    DC5R Engine Leak
    Hey guys, I've got a DC5R that has been sitting for roughly 6months to 1 year.
    There was a leak with the half-shaft seal, I have replaced it and the leak has stopped.
    There was a leak in the Valve Cover seal due to wrong application of sealant after old owner painted it Red. I have replaced it and the leak has stopped.
    Now there is another leak in a third location. I have been looking up, down, left and right. I cannot figure out where it's from. It seems like it's just above, or just below the headers. Seems towards the passenger side corner (near G.box). Does anyone have a clue what it could be? Or what to look for?
    The clutch was replaced, so could it be that the Gearbox was not put back on properly?
    Thanks
    Maybe it could be that the rear main seal didn't get replaced during the clutch change?
    Instagram: @ictorv2 & @00zaku
      do you not have access to a camera? or camera phone?
        Pictures would help greatly mate!
          Yeah photos will help probably gearbox fluid?
          DC5R
            Oem gearbox oil is clear.
              Will post a new thread with photos and better explanation in 2 minutes. Thanks guys
                DC5R Oil Leak Issue (with photos) Repairable?
                Hey guys. Engine was de-greased and has been run for roughly 30mins with and without revs to see where the leak is from.
                1. There is an oil leak coming from just next to the half-shaft where it goes into the Gearbox. Inside that little gap. It can be seen very slightly.
                2. There is an oil leak from where the Gearbox joins into the engine. (Photo taken from underneath car). Clutch has been replaced, so i am assuming it was not sealed back properly. How is it supposed to be repaired? Hondabond? Gasket?
                  Threads merged.
                    Originally posted by M@lew View Post
                    Threads merged.
                    Thanks
                      congratulations - that is NOTHING to worry about.
                      probably remnant degreaser...
                        and to be honest - i can see no leaking anywhere in pic 2.
                        (or pictures 1 either - maybe do a red circle around where you think the oil leak is?!?!?)
                          It was run for only 30mins. You cant see it in the photo but there is a small portion in gap that leaks slowly and grows if i go on a long roadtrip.
                          I don't think that there isn't a problem because engine oil has gone low for some reason.
                            please draw a red circle around where you think the oil is leaking.
                            where is the oil puddle on the floor?
                            maybe post a picture of that?
                            and how are you sure the oil level has "gone low" for some reason?
                            you checked it when? & where? & how? who checked it?
                              Will take better photos and upload tomorrow or the next day after a longer running of the engine. Then it will be visible.
