what brand water temp adaptor can I use?
    Hey guys,
    Question for all the defi gauge owners what brand water temp adaptor are u guys using with the defi sensors?
    thanks
    Perry
    i have defi DIN 3 gauge and use trust water temp t-piece adaptor and trust sandwitch plate for the oil pressure and temp. fits perfectly. p.s. make sure u use some of that sealant when screwing the sensor into the t-piece.
      water temp adaptor ,i used Speco ,bought at autobarn $25.
        I use some taiwan stuff.....about $15 bux....good enough though....
        Mugen Whore #2
        ヒール&トウのやりかた
        1)ブレーキを踏む
        2)クラッチを切る
        3)シフトダウンしなから、
          アクセルをぶかす
        4)クラッチをつなぐ
        :blah:
          strange my trust sandswitch plate didnt fit my oil temp sensor?? as I advised from my last thread
            Which sandwich plate is this ? The sandwich plate for gauges only, or is it for the oil cooler ?
              my bad sandwich plate from the trust oil cooler kit which has holes for the sensors.
                water temp adaptor sold at justjap auto imports
                justjap.com
                many sizes
                  What do yo mean by not fit? you can't screw it in or just can't get it in all the way....if you can manage to get it in then its ok....mine didn't go all the way in either....if thats the case then you are fine....unless you can screw it in.....
                  Mugen Whore #2
                  ヒール&トウのやりかた
                  1)ブレーキを踏む
                  2)クラッチを切る
                  3)シフトダウンしなから、
                    アクセルをぶかす
                  4)クラッチをつなぐ
                  :blah:
                    I'm pretty sure the trust oilblock adapter has atleast one space for a sensor. I had to drill the plate to make room for another sensor so I have pressure and temp.
                    You can by an additional sandwich plate for about 80 bux which has up to 2-3 sensor spaces, but the problem with DC2R is that there's not enough space to fit it.
                    ..:: Disciple of the DDang Driving School :: ..
                    - Don't rev at me, I get scared -
                      the defi senor was too big, I've been advised by IS motors they need to redrill the thread order to make it fit.
                        Sensor too big hey, try looking for thread adapaters from HKS, Greddy/Trust.
                          Vin, he said the the defi senor was too big, so the thread adapaters wont help
                            There are many thread adapators out there, I am sure defi can help him point to the right one.
                              Hey Perry , is your Defi temperature sender look like this: ; i drilled and taped (1/8 NPT)into my sump drain plug. For the Oil pressure sender i put Tee adaptor at OEM oil sender. Are you in Melbourne? i can lend you the tap if requires, no problem.
