Aftermarket rear sway installed with Mugen Twin Loop for EP3 problem
    This is for all the EP3 owners with Mugen Twinloop exhaust.
    I'm getting a little rubbing noise coming from the rear after installed my aftermarket rear sway today. My question is have any EP3 owners experienced the same problem?
    Perry
    Could exhaust be rubbing from vibration? Try mount it higher so it clears your rsb?
    CW DC5R Build
      It only makes rubbing noises when I go up speed humps and driveway, unfortunately I can't mount it any higher.
        Sure it's your exhaust? Did you grease the bushings?
          did you put grease on the sway bar bushings when you installed it?! i didn't have any grease when i installed my rsb and it made squeaky/rubbing noises when i went over stuff. got some grease and greased up the bushing and it was gone
          ^ beat me to it matty. lol
            Care to share what kind of grease you used ?
              You may be faster on the street with your beast but I'm faster on the forum!
              I used lithium grease which I also use on some components on my bike. Pretty readily available from a lot of places.
                All POLY bushes whether it be hardrace, whitline, superpro, nolathane ect. require being greased..
                Whiteline supply lithium grease with their bushes..
                Nolathane supply a molybond type grease..
                Superpro supply an industrial type petroleum jelly,, its like thick vaseline..
                No idea what hardrace supply, have never had experience yet, maybe another CITR mermber can give feed back on what type...
                I personally dont use any of the grease that is supplied with these bushes, through experience i have found that PBR rubber grease works the best...
                sigpic MRDC5S
                  Cheers guys I do recall speaking with the mechanic when we open the package and we mention there weren't any grease supplied. I don't recall him greasing it toooo. I guess ill find out on Saturday.
                    Ok guys found out the bushing has been greased up before install back to square one again anything else it could be??
                      What end links are you using?
                      Ph: +61397947767
                        Standard ones.
                          Added more grease to the bushings noise went away on bumpy roads but going up driveways I can hear it again *sigh*
