Hey guys, my driver's side door won't shut all the way. The car still locks and everything but when from the out side, the door doesn't close flush to the body work. Any ideas why this would be ? I dont have any photos atm but will try to get them up by Monday !
DC5R driver's side door won't close all the way?
Originally posted by cwdc5 View PostI dont think its been in an accident. But is there any way to resolve this issue ?
If its just sticking out a little you can adjust where the door locks onto, the little U shape metal thing the door locks on can be loosened and pushed in further if you must.
Originally posted by Flippit View Postopen the door then close its so its still open but not closed (if that makes sense) see if the door lines up or if it hangs low, then when you close it slowly see if the sort of 'lifts up' as you close it?
Originally posted by cwdc5 View PostOh thanks for that ! Would you happen to have a picture of this "U shape metal thing."
You can not adjust the lock (pictured) you adjust the striker on the b pillar on the body of the car. The striker is the loop that the lock pictured slides into when shut. I think it's a Phillips head number 3 size and should be tight. The plate of the striker (loop) should have markers on it. Just cheak the bump stops (round black bits in picture at bottom of the door and just above the lock) thay can sometimes wind in or out.
