Front camber adjustments
    Hey guys. Search came in with nothing so here goes.
    I'm getting a set of spc front camber bolts to do some adjustment on the front. I've never done camber on the front before so when I found out that the box only had two bolts, I was a bit confused since the front suspension has four bolts in total.
    Can someone shed some light on this?
    Thanks guys
    CW DC5R Build
    A box will come with only 2 bolts. Depending on which company and how your suspension is set up, you can achieve -1.5 camber with each bolt.
    Some people will recommend running 1 bolt each side but I am running 2 camber bolts each side since I have some aggressive wheels. For daily driving with stockish wheels, -1 to -1.5 camber is enough and you'll notice a difference in handling.
    Instagram: @ictorv2 & @00zaku
