After having a HID plug-n-play kit for a while and being unhappy with the light output, I started to look at other options for my DC2R. After doing much research on various forums such as www.hidplanet.com I decided what I needed to do was a proper HID projector retrofit.
This involved replacing the Halogen projector unit in the headlight assembly with one designed specifically for HID light. The difference is that a projector designed for HID will have a greater and more even light spread than one designed for Halogen bulbs.
So, to begin I sourced some current model BMW X5 projectors. These are BiXenon projectors which means they have an electronically controlled shield which moves when switching to High-Beam (shown in pictures below).
Some pictures so far (all testing only, the projectors have not yet been fitted to the headlamp enclosures)
The X5 BiXenon projector units :-
The light output from approx 10 metres :-
The pretty blue bit around the cutoff region :-
With High-beam switched on :-
