DC5 rotors
    DC5 rotors
    Hey
    recently my brakes are making a screeching noise when i brake so i took it to a shop and got them to check my brakes. they told me you have heaps of brake pads left and it is my rotors that need replacing. so i am wondering what do i need to look out for when getting new rotors for my 2003 honda integra dc5 base model please help me
    thanks
    My First Daily DC5 Build - http://forum.jdmstyletuning.com/show...da-Integra-Dc5
    OEM replacement or after a performance upgrade?
    Otherwise only thing to look out for is make sure you have the right size for your model.
      Re: Dc5 rotors
      What pads are you currently running?
      It is a possibility that the compound of the pad you are using is causing the squealing
      Ph: +61397947767
        really just after something that i can use everyday as it is my daily car. what is the price difference?
        and any chance you know the size for this car?
          not really sure about the pads cause the car was second hand and it wasnt making the sound when i first got it. and the mech told me it is because the rotors aren't smooth any more.
            I'd probably recommend RDA Rotors, cheap and next to OEM grade. It should be great for daily use ...
              Like I said on Ozhonda (r3ckless) make sure you find the correct and exact part numbers for a base sized ROTOR, otherwise if you plan on keeping the car for a long time to make the purchase worthwhile, upgrade to Type R/S calipers so that rotors/pads are easy to source in the future.... if you plan to sell the car in 2-4 years time, no point upgrading...
                Thanks for all the replies =)
                Hey Guys i have a few question regarding DBA rotors i was wondering can you help me out.
                At the moment i am looking at the DBA street series slotted rotors 2508S will these fit my car?
                How do i tell if the rotor is from DBA is there a logo or a part number on the rotor itself?
                so i am looking at some second hand rotors can you have a look at these photos and see if they are the DBA street series slotted rotors (2508S)?
                  There RDA's.
                  DBA slots cross each other
                  Check pics below
                    Originally posted by Karl View Post
                    There RDA's.
                    Check pics below
                    [ATTACH=CONFIG]5138[/ATTACH]
                    [ATTACH=CONFIG]5139[/ATTACH]
                    is the first photo dba and the second rda?
                    and what about this? http://www.kseriesparts.com/cr/DBA-2508S.html
                      There RDA's.
                      Check pics below
                      Karl those are the new DBA slot design, the old design (not sure if still made this way) looks like a normal rotor with diagonal slots.
                        Arrr, ill shut up then!
