Hi guys
I am planning to buy the Endless 6 Pot Compact Mini Caliper - System Kit from PerfectRun Japan. I have already enquire to them if there is a Inch Up Kit availiable for the EP3R (since it will fit AUDM DC5R) but apparently there isnt anything they can get from Endless Japan. So I have come to a conclusion if I buy the System Kit which includes the 300mm 1-piece rotor to suit, would I be able to use a 330mm 2-piece rotor on this same system without any modification or do I need another bracket to suit the bigger rotor ?
My plans for the 330mm rotor was to get DBA to make it up for me using my existing rotor hat I have which is a 300mm 2-piece system but there is not much life left in it. Hence why I have thought about upgrading to something better!
So hopefully someone out there can help me out
Thank You
Stephen
Thank You
Stephen
