Passenger door not getting power
    Hay guys wondering if any one has some ideas on why my passenger side door would not be getting any power?
    I have tested the grounds and getting a solid 12.5v reading. Fuses look ok also. Hoping some auto elec's are out there
    Cheers
    teamGROUNDzero
    http://www.teamgroundzero.org
    What part isnt getting power. Power window, central locking extra. Also the door isnt used as a ground as it pivots extra. A ground will be run in with the wirering loom. Check that ground wirer!
      door actuator? i dunno im guessing.
        I have the same problem with my passenger door. Central locking doesn't lock or unlock from driver's door or remote. Apparently it's a common dc5 problem. Just need to replace actuator.
          When I hook them up directly to power I it all works. Ill test some more stuff tomorrow. Can't bet my blower to go either
          teamGROUNDzero
            All fixed
            teamGROUNDzero
