Hi guys. Noticed the rear trailing arm bushes on my integra are shot. Split in half. My question is the press really needed for replacing them. or can it be done safely to the new bush with a hammer?
Thanks guy.
As above yeah you can smack them out with a hammer, but I'd put them back in with a press as they have to be pressed in the correct distance. Use a rubber bush, don't bother with urethane.
