Goodridge Stainless Brake Lines DC5
    Hi all
    I'm after a set of stainless brakelines for my '03 DC5. It seems like Goodridge have a pretty good rep, so was going to get a set of these.
    Just wondering if there was any difference between the RSX or Integra kits as I was looking at RSX kits from the states for around $150, then I saw DC5 integra kits on the UK for around $100.
    Also just wondering if all these kits come rubber coated as I always though the outer layer was the braided stainless steel?
    Thanks
    Originally posted by BRACETDC View Post
    Hi all
    Thanks
    If the kit from the UK is intended for the JDM Type R, which it likely is because they only got that model as a grey import and no others, then yes those lines will be slightly different to those made for the RSX Type S. See this thread: LINK. The difference isn't much but you're better off getting lines intended to fit the RSX Type S.
      Okay I am getting JDM Brembos though so would the UK version be better for these?
      Also do they all come with the PVC coating cause this seems a bit cheap?
        Yeah the UK version or something from Japan would be better in that case. I have seen Goodridge lines for DC5 both with and without the PVC coating so be sure to confirm the ones you are getting actually have it.
          So is the PVC coating better then?
            yea get pvc coating, it'll protect the lines against any elements
              anyone know where to get a set of these goodridge lines from that'll fit rsx?!
              thanks.
                There's a sale thread with a set
                http://forum.clubitr.com.au/showthread.php?p=247382
                CW DC5R Build
