So im not sure if this is where i should be posting this, but hope someone can lend some advice regardless. Was cruising around just an hour ago due to boredom with my mate, took it to an industrial area to teach a friend how to drive manual. It was pretty dark so throughout the drive in the industrial area i had my hi beams on aswell, so after he pulls over and im about to pop back in i realised my driver side low beams (HID) isnt working and my hi beam isnt as bright as it should be. After trying to fiddle around and get my finger in to see if theres any loose wires, which didnt really work the hi beam on the driver side cut out aswell, now both driver hi beam and low beam dont work but the passenger hi and low work like its meant to be. Both the driver side headlights hi and low kinda flicker when i turn the lights on but just eventually stop so im not sure if its possibly a wiring problem...
Has anyone ever had something similar happen? maybe after installing HIDs? ive had the passenger side hid go out before, biggest pain in the behind to take it out and replace until i realised it was just a loose cable which after putting it back in fixed everything. However this time the driver side cables dont seem to be loose from what i can see and no clue why it would make the hi beams turn on at the same time. I am the worst at dealing with electrical/wiring problems so if any1 possibly has an idea or know what might be the problem please help.
Cheers,
Dee
Cheers,
Dee
