hi,
dunno if this is covered but my car is now running -4degree camber with the buddy club n+. no camber bolts nor camber plates.
my question: is it possible to adjust the camber manually by loosening the top bolt of the strut and moving towards you and back? (buddyclub n+ has top slotted hole to adjust camber with oem bolt, can achieve long ranges of camber)
wont that cause the camber to slip over time?
my alignment person said if i adjust camber like that, it will cause to slip to max camber after driving in bumpy roads or holes or even track.
my main goal is to achieve 2.5-3 degrees.
, wat happens if u over tighten ? haha
