ive recently installed coilovers onto my car and basically since then, ive had an issue with steering.... when i turn the steering wheel, it seems that i have a "empty" point, where when i turn the steering wheel, the tyres wont move until past a certain point... say for example, i was turning my steering wheel left, id have to turn the steering wheel past 30 degrees from the vertical centre before the tryes actually move with the steering wheel, and vice versa for the when i turn the steering wheel to the right hand side....im guessing it might be due to the tie rod end, which was damaged during coilover installation??? or otherwise it might be the fact that i kept rotating the shaft connected to the tie rod end and didnt rotate it back to its original position??? any help would be muchly appreciated!!
Suspension Issue
get a 28 point safety check done at Pedders - $14
we cant diagnose your problem over the internet - it sounds quite bad too - so be careful driving - you might be in danger...
http://www.pedders.com.au/catalogue.asp?prod=28%20Point... retired/
