Parts
1. Wire harness, it is the same harness used in 1998 and newer Honda accord, and 1999 and newer Honda civic etc
2.(depending on deck) Small Trim Ring *see pics below*
Ok so to start off, what you will need to do is locate the center dash panel below the radio and directly above the cupholder/tray and on either side. There is one small area on either side where you can see an slot that you can use your tool of choice to help pop the panel out (seen here).
![](http://thanh-do.net/clubitr/HeadUnitInstall/headunit1.jpg)
This is what it looks like off you can see all the clip locations as well as you will need to unplug the power outlet.
![](http://thanh-do.net/clubitr/HeadUnitInstall/headunit2.jpg)
Then it gets a little tricky, only because it may require a special tool that some people might not have, either a right angle screwdriver(skewdriver) or a 8mm socket on a flexible extension to get them out, there are two.
![](http://thanh-do.net/clubitr/HeadUnitInstall/headunit3.jpg)
![](http://thanh-do.net/clubitr/HeadUnitInstall/headunit4.jpg)
After you remove both the lower screws position your hands behind the plastic *pocket* and push out evenly and the entire dash surrounding the radio will begin to pop out, being careful on the side where the hazard button is because there is less support and more risk of cracking the dash trying to pop the clips out of the dash
