Hey everyone.
I bought a set of BuddyClub RSDs about 4 weeks ago.
however i did bought the EP3R ones..
Now I have spaced the rear bushings out with washes to fill the gap (not issues) and was also given brand new 'aftermarket' tie rod ends so i could fit the fronts. These are a similar length to the DC5 ones.
After fitting the fronts at a reasonable height I got a mate to adjust the toe.
Now it looks like we are already running low on threads for the tie rod ends and its not at the height i want. The lower we go the more threads we will loose.
Quick fix????
Should i purchase some OEM EP3R tie rod ends? (are they longer thread then DC5?)
Get Inverted?? (if so what brand)
Replace the rod itself with something like this? http://www.dvrace.com/tierods.html
Any info will be a great help.
Cheers
Quick fix????
Cheers
