Fuel Filter
    Fuel Filter
    Where can i go to get my fuel filter changed? is it an easy replacement that any old mechanic can do or can it be stuffed up and do damage if poorly done (since its regarding fuel system).
    OEM replacement ok? $97 for OEM or is there aftermarket for this?
    is it neccessary to change fuel filter? says so on servicing manual. (im getting bad kms out of a tank)
      it requires the removal of the fuel pump from the fuel tank and quite specific "quick-connect" fuel line knowledge...
      although this is unusual - i would not recommend it to a novice to try at home.
      i doubt there is aftermarket fuel filters...
      how many KM has your car done?
      why do you think you are getting low KM per tank?
        I thought he ment the fuel filter in the engine bay not the funny gauze thing attached to the fuel pump..
        heres a DIY from Team integra that guides you through..
        http://www.team-integra.net/sections...?ArticleID=391
        I never changed the gauze thing on the pump side before..
        small tip.. before doing this though..
        if you have any cuts or new wounds.. while doing anything with petrol.. make sure you use gloves ^_^... you will thank me for that =P...
        Memorable quotes
        Originally posted by Q_ball
        Originally posted by Wayne
          ohh and BTw.. i have seen it done without doing the step with disconnecting the clip to the fuel pump/start engine till it dies part
          just make sure you got alot of rags.. and atleast releast the preasure from the tank via Fuel cap (where to pump gass in)
          Memorable quotes
            the term fuel filter seems to be referring to two things...are there two different names for the two?
              i dont actually know what the fuel pump filter thing is called..
              but AFAIK i have always called the black thing sitting in your engine bay.. the fuel filter =P.. the DIy called it s fuel filter so i call it a fuel filter =P
              Memorable quotes
                Thanks for the link btw! should help.
                  If your not confident with your mechanical skills you might wanna ask someone whos good with this stuff to do it..
                  i dont consider it a hard thing to replace.. but its a scary one atleast if you never did it before..
                  Memorable quotes
                    Chosta - your profile says you have a DC5 - can you confirm this?
                    if so, ignore Wlee2, he is referring only to a DC2...
                    and follow my advice, which refers to a DC5 situation...
                      ah okay...so its not the same?
                        i dont want to do at Honda, casue labour is too expensive.Any suggestion where i can get it done?
                          ^_^... i totally forgot this forum is full of DC5 owners...
                          ... my bad.. ignore everything unless you own a Dc2 =P...
                          Memorable quotes
                            ummm... yeah DC2 is easy. Just take it past IS motor racing, or any garage of the sort. depends if you trust them etc... That's really important to me. They won't charge nearly as much as Honda would.
                            Originally posted by ChargeR
                              Guys, please don't refer to any DC2 help...The guy has a DC5
