JDM K20a ADM k20a2 engine swap
    Hey guys,
    I recently bought a jdm k20a from canada, I'm putting the engine in my Aussie spec dc5r! I just want to know if theres anything u guys know of that I'll have to changed or bye to perform the swap. Ive been told it's a bolt in fit and I've done research and can not find much! The transmission and exhaust is just au factory but ino the jdm manifold is different! Help would be appreciated as I'm kind of a biginer cheers!
    Is ya au k20 blown?? Why u doin a engine swap??
      Sure did blow threw a conrod out of the block
        Just a straight drop in.
          Everything will line up and can be used.
          teamGROUNDzero
          http://www.teamgroundzero.org
            I have a JDM K20A ECU if you want it
            Ph: +61397947767
              ^ that will help with the Jdm power out put
              teamGROUNDzero
                Thanks very much but when I bought the long block it come with the ecu
                  Oh damn why didn't you go for a K24 ... and also you should look into engine mounts while your at it!
                    Sorry if this sounds stupid how much better is the k24? I don't know a thing about it or even consider, please educate me lol?
                      k20. 2 L. k24 2.4 L Alot of poeple put the running gear from the k20 in to the k24.
                        Yea that was the only difference I was aware of! Much of a power gain in the k24 considering?
                          K24 will have better torque through out the rev range. With similar mods K24 makes similar peak power as K20a, low to midrange K24 makes 10-15kw more.
                            Ohhh right is it deffs a better option and as easy to do? Basically is it worth selling the jdm k20 to by a k24?
                              It all depends on your future plans
                              If you go K24 powerplant, you will need a tunable ECU (i.e hondata Kpro). You can retain all factory headers and intake system, but its recommended to upgrade these items while your at it
                              A K20 engine replacement is straight forward and there is no fuss. Simply take out and replace.
                              If you were to keep the car and do bolt-ons to the K20, i would stick in a K24 and work off that platform
                              Send me a PM if you want more details
                              Email - benny@bypracing.com
                              STREET - TRACK - DRAG
