VTEC not engaging at all after rain
    After noticing my vtec kickin in 6200 for a couple of months after the brisbane the last few dayz now my vtec isnt engagin at all . Im scared iv broken somfin and its now bookd in at honda for service what i have done ??
    Sent from my GT-I9100 using Tapatalk
    Low OIL pressure!!!!!!!! Your car is probably burning oil.. Ive seen some cars engage late because of low oil. And not engage at all because the oil is that low!!!!!!!
    Check ya dip stick.. You running stock ecu??
      Service your car? Sounds like you're having a lot of problem with your VTEC.
        Iv just top up my oil a week ago and yes its a stock ecu . I check my oil nd water everytime it comes out . Think iv fukd a push rod or valve wid this water latly .
          wow.
            http://forum.clubitr.com.au/faq.php?...aq_forum_rules
              Is the motor still running?
              I've had a similar issue with another customer vtec not working. We got it sorted out. Its a process of elimination. Expect a nice bill from Honda
              Email - benny@bypracing.com
              STREET - TRACK - DRAG
                Take to honda.. Get them to see if you car has any error's.
                If were me id start by leaving battery disconnected so the ecu restarts.. Change oil and filter, Maybe even use oil flush.. Oil filter may be blocked or stuffed and is affecting oil pressure..
                Use quilty oil and filter.. not ryco crap
                  To me, I'm thinking it would be the VTEC solenoid. Since you said it has been playing up and then it's pretty much not engaging. If not that then you have oil pressure issues which makes it stop engaging, like as above.
                    Thanx for help guys hopfully hondas can sort it wid the service .im pretty cut atm that cars my baby and i did reset the ecu yesterday and nothing ..
                      could possibly the VTEC soleniod...... had another FN2 similar situation to yours.....
                      [b] Life starts at 5500rpm [b]
                        Yeah those damned pushrods are always playing up in my DOHC Honda...
                          Try to run 12v power straight to the vtec solenoid. if it doesnt click, then thats your problem!
                            Not sure if serious...
                            If you aren't mechanically minded, take it to a mechanic and have them check over the car. If the car is still running, I highly doubt you have done any serious internal damage.
                              im sure he is serious.
