I have a slight problem, last night I turned my car on and it started sputtering/hesitating at idle, revved it a bit and it sounded very choppy/farty, I think its coming from my K&n pod filter, I hear a lot of hissing noise coming from it. It only happens during the night, think it may be the cold air and something wrong with my temperature sensor. Also sputters when I accelerate, tho after awhile it goes away. possible vacuum leak?
Car sputters. Vacuum leak?
Vacuum leak won't make it sputter on acceleration. Sounds like a sensor is playing up.
If there was a vacuum leak you'll have a abnormal idle rpm's i.e higher then usual.
Is there a solid cel light on?BYP Racing & Developments
pull ur AFM out and spray it with some good contact cleaner. could be as simple as thatTyrepower North Melbourne
Christopher Lai | Owner - Operator
0433 33 90 38 | 03 9329 7333
PM/SMS for a quote | Tyres / Wheels / Alignment
212 Abbotsford St, North Melbourne
Honda DC2 | Nissan S15 | BMW Z4M | Honda DC5
What car? Honda's run MAP sensors not maf. Remove the intake arm and start the car up. Place your hand over the throttle body, if engine dies there no vaccum leak if engine still running there a vaccum leak.BYP Racing & Developments
