Ok i have somthing happening that i cant figure out.. If my car sits there for say a week, then check the oil level with out running it, it will show on the lower dot.. The ground is 100% level ect. If i take it for a quick drive, then let it settel for say 10 minutes. It will show at the high dot... Don't under stand why im getting differ reading by so much.. I changed the oil today.. I dropped just bellow 4 L.. So the right amounts was in there!! Its a dc2R by the way. Could some one shed some light.. Thank you!
Oil levels
Oil levels
Yer.. the thing is, If i drive it then check the oil the next day the level will be fine.. Its only if the car isn't drivin for like a week that it reads low!sigpic
Na if i drive it and check the next day its still alright.. Only when car's been sitting there for a week with no drive that it read's low!!sigpic
Check the flux-capacitor level isn't low, that could be giving you false oil level readings.
Quote:
JHDM-B18C7 >>>>> Source Code: DC2R 00-0016SOLD
Yer that explains why i haven't been able to travel through time recently!! Thanks heapssigpic
Originally posted by DC2RKID View Postcant find a long enough strip to get to 88miles per hour!! takes to long to get there :P
Yer 4 sure... Either that or i was going to fast for time to keep up!!!!!!!! Any ways enough crap.. Still haven't resolved this problem!!!! HELP plezsigpic
Man, I wouldn't worry about it. Does your car drop any oil when you park it?
Na no oil leak.. And i drop the same amount of oil as i put in!!.. So no consumption! Thanks m8sigpic
