Passenger side headlight light not working
    Problem solved, thanks guys
    The plug has probably either melted or rusted on the inside.
    You need to cut off the plug and replace it. This happens when you use light bulbs which draw a high wattage.
    You can purchase replacements from e bay
    http://cgi.ebay.com/ebaymotors/9006-...9946QQtcZphoto
    I purchased a replacement set from them, there very high quality items and use good gauge wiring. Just message them for a shipping price.
    /Oo ___H___ oO\
    |=_/_______\_=|
      find a spot in the loom and strip off a bit of wire and run the multimeter there.
      Follow the loom back until u stop getting voltage and that will narrow down ur places to look.
      just make sure you heatshrink or wrap up the exposed wire extremely well when you're done
      Team Misplaced CT9A Owner #010
        stock bulbs?
        z10 says:
        z10 says:
          Ok will try the ideas mentioned, thanks guys. Ah yeh i used stock bulbs and also my hids to test if it was a bulb problem when it first occured.
          I forgot to mention i was running hids originally when the problem occured, then i switched back to my stock bulbs
