Recommendations for custom intake pipe
    Hi guys,
    My stock radiator pipe burst on me from the the larger throttle body and a new one is required. You guys have ideas for any good workshops in Sydney that can fabricate a custom pipe
    where abouts are you located?
    most exhaust shops can do it. id be hitting up either
    - Westside @ padstow or
    - Northmead Performance Exhaust @ Northmead.
    - Customworks @ Brookvale
    teamGROUNDzero.org
    shak - est 2004
      cool thanks.. im located in sydney hurstville area
        not really clear what you are asking?
        is it metal piping?
        and it BURST?
          Should have been more descriptive
          The stock black rubber pipe that connects from airbox to throttle boddy started to split in the area where it connects to the TB
          Must be from the continuous stress and heat and the fact that throttle body is larger than stock...
          It's all good now. Will be getting a metal custom pipe to replace it.
            Its the intake pipe. The radiator hose is below that pipe.
              Right..thx for the correction
                edited the title for you
                  Northmead Performance Exhaust @ Northmead. There great there!!!!!!!
                    Thanks guys... ended up getting it done today at a place in Mortdale from a friend's recommendation. Will be looking to paint the chrome pipe wrinkly black for a more subtle look
