DC5R Trailing Arm Removal
    Hi all,
    Just wondering with the two bolts holding the trailing arm to the hub assembly, one of them is a 17mm bolt with a welded nut so that's easy to remove. What about the other bolt which has an eccentric washer welded to the bolt head? Do you crack open the 17mm and then pry the bolt out using a flathead?
    Looking at bolts 15 and 16 in this guide:
    http://www.team-integra.net/forum/bl...placement.html
    Cheers to all in adv.
    Kevin
    Winton: DC5R - RE001 - 1.45.9
    Nws done. Just had to smack the damn guy out.
