DC5R starter motor part number
    Does anyone know the exact part number for our DC5R starter motor?
    1 30201-PH9-004 RING, SNAP (DENSO) $1.94 $1.46 1
    2 30202-P3F-003 COLLAR, CLUTCH STOP $4.34 $3.26 1
    3 31200-PRB-A11 STARTER MOTOR ASSY. (DSDHL) (DENSO) $626.52 $469.89 1
    3 06312-PRB-505RM STARTER, CORE ID (9742809-328)(428000-0010) (RMD) $268.08 $201.06 1
    4 31201-PNE-G01 HOUSING, DRIVE SIDE $67.75 $50.81 1
    5 31202-PRB-A01 END FRAME, COMMUTATOR $21.67 $16.25 1
    6 31202-PR4-003 BOLT, THROUGH (DENSO) $6.05 $4.54 2
    7 31203-P3F-003 LEVER, PINION DRIVE $21.57 $16.18 1
    8 31204-PRB-A01 SWITCH ASSY., MAGNET $223.02 $167.26 1
    9 31205-PNE-G02 YOKE $144.03 $108.02 1
    10 31206-P3F-A51 ARMATURE $342.97 $257.23 1
    11 31207-PNA-003 CLUTCH, OVERRUNNING $208.52 $156.39 1
    12 31208-P3F-003 SCREW, PAN (4MM) $1.90 $1.42 2
    13 31213-PNA-003 SHAFT, DRIVE $156.35 $117.26 1
    14 31213-P64-N01 COVER $4.70 $3.53 1
    15 31214-P3F-003 GEAR ASSY. (INNER) $42.15 $31.61 1
    16 31215-P3F-003 GEAR, PLANETARY $21.57 $16.18 3
    17 31216-RAA-003 SHOCK ABSORBER $10.95 $8.21 1
    18 31217-P3F-003 PLATE, SEAL $5.53 $4.15 1
    19 31219-P3F-003 WASHER B $2.88 $2.16 1
    20 31218-P3F-003 WASHER A $2.88 $2.16 1
    21 31220-PH9-004 NUT, HEX. (8MM) $2.18 $1.64 1
    22 31220-P3F-003 WASHER C $3.60 $2.70 1
    23 31223-PA0-006 NUT, HEX. $1.90 $1.42 2
    24 31231-P3F-003 PLATE, BRUSH HOLDER $48.52 $36.39 1
    25 31291-PRB-A01 STAY ASSY., ENGINE HARNESS $3.60 $2.70 1
    26 31292-PLR-A01 BOLT-WASHER $19.28 $14.46 1
    27 94510-15000 CIRCLIP (OUTER) (15MM) $0.62 $0.46 1
