Disclaimer: The following is provided as a GUIDE ONLY, and neither myself nor ClubITR take any responsibility for the outcomes of someone else doing the following. You follow these steps at your own risk!
AIM – To have additional gauges inside the car that work of their own sensors.
The car I’m installing them in, is my DC5 Integra Type S
TOOLS – there’re a lot of tools used for this install…..I’ll try to list them as I go through the steps.
SPEP 1 – you’ll need gauges……. & various other parts in order to make the gauges work.
I brought mine all from the EBAY, 60mm type.
http://stores.ebay.com.au/gaugetuner...id=p4340.l2563
So have all these before you start!
![](http://img152.imageshack.us/img152/531/copyofstep1.jpg)
STEP 2 – Installing the radiator adaptor.
You’ll need 35mm adaptor, Sharp Stanley knife, Phillips head screw driver, multi grips/pliers, size 12mm spanner, HONDA 3 way liquid bond (for water temp sensor) HONDA radiator coolant & 42mm radiator hose clamps.
Check to see the best location for the adaptor to go. Remember that the sensor & wires need to run of this so it needs to be in a location easiest to get too.
![](http://img852.imageshack.us/img852/4136/copyofmarkingthehose.jpg)
I marked mine here.....well a few times just getting it rite. I cut off about 10mm. before removing the radiator hose to cut.
Take off the radiator cap. We need to drain out some radiator coolant, so when we take the hose off coolant won’t spill everywhere.
![](http://img848.imageshack.us/img848/8894/copyofdrainplug.jpg)
I had already taken my front bar off….as it was in the way of the radiator drain plug. I’m not to sure with the OEM one because I no longer have so you might no need to re-move it?
I drained out about 1 litre of coolant.
![](http://img153.imageshack.us/img153/7587/copyofdraincoolant.jpg)
Before I added the adaptor, I screwed on the water temp sensor….remember to put on the HONDA 3 way bond on thread to make sure it doesn’t leak.
![](http://img837.imageshack.us/img837/6820/honda3waybond.jpg)
Once this is installed just top up with some new coolant.
![](http://img692.imageshack.us/img692/8928/copyofcoolantaddaptoron.jpg)
STEP 3 – Oil sandwich plate to allow for oil temp sensor & Oil pressure sensor.
Motor Oil, Oil filter, 12mm spanner
Now this procedure is the same as if you were to change your motor oil.
Jack the car up, put stands under car make sure all is safe!
Remove your oil cap, undo oil drain bolt, remove oil filter.
![](http://img222.imageshack.us/img222/2622/copyofsandwichplate2.jpg)
Do a check fit to see where the best location is for installing the sensors.
![](http://img831.imageshack.us/img831/1750/copyofsandwichplatefit.jpg)
Once this has been determined, screw in both sensors. Remember to put the HONDA 3 way bond on threads to stop any oil leaking! Also don't forget to fill the engine with oil once it's all done.
![](http://img694.imageshack.us/img694/4204/copyofsandwichplatewith.jpg)
