Hey guys,
I recently did my bottom end bearing
And need some pointers on what i should do replace stock or upgrade it while its apart.
Some ideas i had
2l strocker kit with a 92 or 95mm stroke
probably go to a 82mm bore and highcomp pistons of some sort probably around 12.5 or 13cr.
Upgrade the whole valve train and either stage 2 or 3 cams hence the high compression to run them.
then all the other little stuff you need to get it all running. ect.
was thinking b20 but the compression i want to run is apparently to high for the stock sleaves and ill have to get new ones which is expensive.
but feel free to comment and give me ideas aswell
I would like about 200 to 250+ whp
thanks
Some ideas i had
thanks
