DC2 antenna
This topic is closed.
    DC2 antenna
    Has any one changed there antenna to the s2000 one???
    These two threads might get you started: LINK and LINK
      yeah i have
        how do u make the ariel go up in dc2 =/
          turn the radio on whilst ignition is on...
            something wrong with mine then lol... doesnt go up
              looks better when its down man trust me
                DC2RKID should be able to help?
                bu my memory tells me it is the blue wire...
                  Na just did my deck it was yellow and green. But thats only the switch active to the relay at the motor.. It should have permenant power( white and Red ). the switch active energizer's the relay. Check fuse.. Doe's it make a knocking noise when the radio's turned on.. If so the power's fine. Its stuck or bent.. If no noise check for power!!!
                    the colour of the "ANT" wire coming out of the deck is yel/grn?
                    i was pretty sure the standardised antenna motor controller wire colour for aftermarket headdecks is blue...
                      Oh yer The sw active coming out of a aftermarket deck is blu white.. So that connects to your antenna and amp sw if needed..
                        The yellow green is the Sw to the antenna that energizer's the relay.
                          solid blue wire
                            solid blue is ant wire blue with white stripe is remote.... if u connect solid blue to an amp the amp would only turn on when tuner is selected
                              That what i said!!!
