Toda DC5 Catalyst Mod Picture
    Does anyone have a picture of their DC5 Toda Headers being modified for the cat by Toda Australia?. If you could wouldn't mind just seeing a pic of it thanks.
    Norman
    http://firesport.com.au/brand-new-to...--ad147300.htm
    not a good picture but yeh
      off memory se7en, i think the toda one is TIG welded. In the picture it looks like its been customised as a bolt on.
        How can you tell that is not TIG welded? My eyes aren't that good. Adrian from Toda AU can confirm but I believe the way he attached all the cats to the DC5 headers is with a flange and donut gasket with spring bolts as pictured.
          well that header was done my toda australia....best bet is to pm toda australia if you have any further questions =)
            Thats ok then guys. I'll double check with Adrian then. Cheers though. And when I meant TIG welded i meant the part where 2-1 isn't a bolt on but a straight weld. It currently has a spring bolt on so you can detach the catalyst whenever you like and replace it with a straight pipe for track use. I'm just trying to confirm whether if the Cat is welded straight unto the 4-2.
              I was under the impression that the Toda headers came without a cat or flange, and to get a cat you had to have the cat welded onto the 4-2 section of the header directly. But yeah, contact TODA AU for a better understanding
