anyone else had or seen this issue, my drivers side door lock has starting to stick, and has issues locking when alarm/central locking is enabled. So i am needing to put key in and turn it manually....am thinking the solenoid maybe on its way out, any ideas on what i am up for to get it changed by an auto sparky?
dc2r drivers door lock sticking..
yeah mate i got exact same prob on my DC2R man...ive tryed lubing everythin that is connected to it..its weird it only seems to stick when its cold weather or wet then all of a sudden it works for like a week then stuffs up again lol someone please help us both lol im startin to think the solinoid is on its way out also
Got the same prob with mine hey.. It doesn't work most of the time, then has bouts of unlocking via the key fob;; Fkn sux having to unlock the door all the time with the key.
Quote:
JHDM-B18C7 >>>>> Source Code: DC2R 00-0016SOLD
Yeah I might try and WD40 mine, I can hear it trying to actuate.
yeah thats what happened with mine
if it is hard to push by hand it is prob not the actuator but rather the actual lock is jamming up with crud making it hard to push and the actuator isn't powerful enough
after wd-40 the lock is really easy to slide. like if you can't slide it easily with ur pinky you should open it up.
I had this problem with my DC2R when I had it and it was fixed by changing the actuator.
Picked it up from Jaycar for pretty cheap. I also got a spare one too if anyone needs one as I've sold the car and I was originally gonna change my passenger side one but that didn't need replacing.Team Misplaced CT9A Owner #010
