DC2 Integra Type R ADM
Released:
Engine: B18C7 1.8L DOHC VTEC, 141kW@7,900RPM
Specific: CR 11:1, Cutout@8,500RPM
Drivetrain: 5 speed close ratio, Limited Slip Differential (LSD)
Weight: 1,087Kg
Brakes(F/R): Ventilated Disks xx mm / discs, ABS
Suspension(F/R): Double wishbone/Double wishbone
Handling: Rear sway bar (22mm), front sway bar (24mm), front upper strut brace, rear tower brace (optional)
Standard features: Airbags, power windows/steering/mirrors, Recaro buckets seats, Momo leather steering wheel, titanium shifter
Additional Info: VTEC engagement@5700rpm, Detailed info 1
try to google, i failed to find stock spec of a JDM 96 DC2R
not much difference, but i believe the JDM is lighter and fast 96 model had no airbag, where to facelight 98 model did and was slower to 0-100 if you check on youtube clips
