Want to change spark plugs on my K20A. Wanna see what you guys recommend?
Spark Plugs
IFR7G-11KS are your stock plugs, they are already Iridium plugs and have a temperature rating of 7. No need to go colder (ie 8 or 9)
I would not recommend using hotter plugs (rating of 6 or lower) on the K20A
Unless you have significantly increased your car's power output...there's no point in changing to colder spark plugs.
The point of having colder spark plugs is the capacity of the spark plug to dissipate heat. With an engine producing heaps more increased power from stock, it's recommended to use colder spark plugs to handle the extra heat generated from the increase in power.Last edited by tofu; 19-03-08, 10:28 PM.
Originally posted by dark138 View PostWant to change spark plugs on my K20A. Wanna see what you guys recommend?
i believe the K20A can use the Iridium series of the NGK which are BKr6eIX11..
or if you want a slightly colder plug BKR7eIX11
i am about 99% certain you can use those in the K20a..
The reason i gave a different plug is because i have a feeling the "IFR7G-11KS" is quite hard and very expensive to buy in melbourne..Memorable quotes
Originally posted by Q_ballsome say, his vtec was switched off on his last 4 outings at wakefield....
all we know is hes called The Perry!!Originally posted by tinkerbellif those HA's are 7k old - i will eat my own arsehole...
Originally posted by WayneNever again complain about a honda's reliability just be glad you dont own an Alfa
Originally posted by lukits01 View Postyou guys only ever use Iridium or Platinum plugs?
never Copper?
but i use coppers in my car sometimes.. depends.. but currently i use irridiums in my vtir =P
the code for the Copper is just minus "IX" so BKR6e11 and BKR7e11Memorable quotes
Originally posted by Tiu View Postwhich plugs are higher grade; platinum or iridium?
but Iridium is from the platinum family and is a transition metal i believe..
also irridium is the most corrosion resistant metal there is.. cannot be attacked by any acids or aqua regia.
source WikipediaMemorable quotes
