A thread to share OEM Part Numbers that might be useful to other members.
Useful Honda OEM Part Numbers
Try this site http://jp-carparts.com/honda/figlist...cartype=25408#02 Indy Yellow s2000::::::04 Arctic Blue Pearl DC5R::::::05 White B2600::::::10 Ibis White Q5
from a B20VTEC with B16A/B18C head build:
IACV gasket 36455-PT3-A01
head/block oil control orifice o-ring 15142-PH3-003
rocker shaft oil control orifice o-ring 91306-PJ4-000
oil control orifice o-ring 91302-GE0-000
distributor o-ring 30110-PA1-732
throttle body gasket 16176-P73-004
VTEC cam seals 91213-PR3-004
VTEC rocker cover seal 12341-PR3-000
bolt washer - rocker shafts 12209-PR3-000
VTEC Water pump 19200-P72-013
release bearing 22810-P21-003
pilot bearing 91006-634-008
vss o-ring 91304-PT0-000
14mm drain plug washer 94109-14000
20mm drain plug washer 94109-20000
oil strainer gasket 15221-PW0-S01
MAP sensor o-ring 16075-P07-000
ECT sensor o-ring 91307-PK2-005
girdle dowel pins - sml 94301-12200
girdle dowel pins - lrg 90715-PC6-000
water to oil cooler o-ring 91316-PE7-730
oil pump o-ring 91308-PK1-003
rearmainseal GB end 91214-PLE-003
oil spout - B20A 11107-PK2-003
oil pump end seal 91212-PR3-003
GSR coolant hoses 79721-ST7-000
B20 coolant hose 79725-SR3-J30
oil pump washer 15234-PC6-000
oil cooler water hose 1 19422-PR3-000
oil cooler water hose 2 19423-PR3-000
fuel filter 16010-ST5-933... retired/
I hope other DC2 owners can find the below useful
OEM JDM DC2 Type Rx red stitch shift boot - 83414-ST7-Z10ZA
OEM JDM DC2 Type Rx Stanley flat clear side indicators - 33802-S3N-J01
OEM AUDM DC2 Type R front lip (Championship White) - H0-71110ST7R01ZA
OEM DC2 tail light gasket - 33503-ST7-A01
