Quick question DC5 owners. Should we be hearing our fuel line "priming"? Reason I ask is ever since i've changed my fuel rail, if I don't drive my car for a few days and start it up it runs for like 5-8 seconds then dies. I have to start it like 1-2 times before its running properly. Wondering whether I have a relay issue.
DC5 Engine Start Issue
I've noticed this to, besides the few s2000's the build threads are very quietOriginally posted by NormMorning everybody. The forum has been very quiet lately.
Probably not related mate but since I rarely drive the dc5 again, I have noticed it takes a lot of cranking to start, like 5 to 10 seconds, not sure if it has a problem but it doesn't feel right when it doesn't kick straight over, even my buffalo buck starts straight away after a long break02 Indy Yellow s2000::::::04 Arctic Blue Pearl DC5R::::::05 White B2600::::::10 Ibis White Q5
i drive my car once a fortnight. Yes, I let it prime for 10 seconds, starts first time every time. fuel setup all stock oemOriginally posted by Norm View PostQuick question DC5 owners. Should we be hearing our fuel line "priming"? Reason I ask is ever since i've changed my fuel rail, if I don't drive my car for a few days and start it up it runs for like 5-8 seconds then dies. I have to start it like 1-2 times before its running properly. Wondering whether I have a relay issue.
yep.Originally posted by PG_DC5 View Post... I've never come across this "priming" idea. I thought modern cars were meant to be able to start from cold all the time and driven straight away?
but not if you MODIFY them...
see post #1 for the cause of the issue: new fuel rail = probably doesnt hold pressure like the old one, fuel pump needs to refil it to build enough injector pressure...
Norm - also make sure all the fuel rail seals are OK...Last edited by tinkerbell; 07-08-14, 12:31 PM.... retired/
I would suspect that due to the higher volume of fuel held in the rail, as tinkerbell has said, it will take slightly longer to build and hold pressure.
I have a rule of thumb that you should always wait 3-5 seconds after turning the ignition on before cranking as It will allow your fuel system to fully pressurise and reduce the likelihood of hard startingSleeping Performance & Mechanical Repairs: Balance, Feedback, Response
Ph: +61397947767
^ can be slightly longer if running higher fuel pressureSleeping Performance & Mechanical Repairs: Balance, Feedback, Response
Ph: +61397947767
