High temperature grease for bearings
    Can I use this stuff on my spline shaft and clutch throwout bearing? No honda parts department even knows what the high temp urea grease is!
    http://www.penriteoil.com.au/product...d_products=101
    Ever get an answer to this? I'm curious too.
    What did u end up using?
    eckoflyte
      I ended up borrowing a tub of Penrite Lithium Moly Spline Grease. It comes in a black tub... I checked the tub and it has the same temp ratings as the wheel bearing grease... but I'd suggest you just buy the tub. I'll link it tomorrow if you reply or I remember haha.
        is this it?
        http://www.penriteoil.com.au/product...d_products=499
        I won't be doing anything as critical as spline shaft. Just looking for a decent grease to use on the slave cyliner rod and clutch fork. That penrite looks like the closest substitute i can find for honda high temp urea grease.
        eckoflyte
          i think you can also use moly grease on those parts (well at least i have been for 10 years)
            Originally posted by andrew84tran View Post
            is this it?
            Yep! That's the stuff I used.
