Engine Light ON
    Engine Light ON
    Hey guys,
    I'm about to buy some after market headers. I've heard that once you install the Toda Headers your engine light will turn on. Is this normal and is there a way to fix this? I also read that you have to change the o2 sensors so that it will use the right amount of fuel.
    moved to General Automotive
      Originally posted by LiteX View Post
      Hey guys,
      It's normal, due to more flow.
      You can get an O2 sensor defouler to fool the ecu into thinking it's still using the stock header and cat. It's what I did =]
      Otherwise a tune will fix it.
      I never had an issue with fuel so I don't know about that
        Where may i find a o2 sensor defouler? so the engine light will not be on?
          I bought this one at the time on Ebay, though that seller doesn't appear to be selling it anymore...
          http://www.ebay.com.au/itm/ws/eBayIS...m=290749221847
          You'd want something similar to that and get an angled one for much better clearance.
          Bear in mind these defoulers will not guarantee prevention of the Check Engine Light from appearing, it will just help lower the chance of it showing up
            Its a common issue when changing to a better flowing header.
            Its an easy and cheap fix.
            Mine is similar to this
            Also you may need to extend the o2 sensor wires depending on where the o2 sensor is located on the Toda headers.
            Simple plug and play wire can be found as well.
              Do you know where exactly i can find them? there is heaps on ebay which i dont know which one are good.
                I got mine from ClubRSX site which has now changed to Kseriesparts.
                Great customer service from these guys as well.
                http://www.kseriesparts.com/cr/CLU1-CEL-ANG.html
                (Site has been updated and having a few issues with viewing items, so best to send them an email with what you need...)
                  Which workshop is good to go for installing the headers? (in sydney)
                    I'd recommend Dedy @ Top One or Hume mufflers in Liverpool/lansvale
                      How much do you think the labour cost will be?
                        Best to call and ask
                          I bought a defouler prior to installing my Toda headers thinking the same thing, but ended up selling the defouler as it wasn't needed. Had the headers on for 2 years with no issues.
                            you didnt need the defouler because your cel light didnt turn on? or u just dont mind the light on..?
                              Hey guys, so I recently got my Toda Headers+cat installed at BYP racing. I also bought the right angled defouler off them because they say this will stop the CEL/Engine light from turning on. Everything was good for a week, until today i saw the CEL light lit up unfortunatly =/. So i called back BYP Racing and they said they will fix it for me but there is still a chance that it will turn back on later. Does anyone else have this problem?
