My old headlights were foggy as heck, it seemed irreversible, tried a DIY kit and tried to have it professionally done, was OKAY for a bit but then got worse. Now I picked up a second hand pair of headlights that were crystal clear, installed them today and here is what I've noticed, and it's on both headlights however one is worse than the other.
What could be causing this? I do have an issue I'm in the process of fixing where water is leaking into the boot of the car into the spare wheel cavity with can cause some moisture inside the car (eg; at night the windows start to fog up) so for now I've used a towel, about to completely seal it off or buy new rear gaskets for the tail lights but I can't see how this would cause the front headlights to go all foggy. Any thoughts/suggestions? Thanks!
I've seen quite a few RSX (USA DC5) have the same problem too, think it's pretty pathetic Honda allowed it. With my old headlights, the housing was cloudy and very dense. With the new one's its more like condensation on the inside, like moisture is seeping in somehow but they were dry as a bone today.
I'll give it a try
