Front sway bar end links failure
    Has any1 had problems with ther front swaybars end links.?? I've had to buy some new ones has mine r all striped n loose.. Is this common for them to fail?
    Stripped? did you or anyone fiddle with it? perhaps it was incorrectly torqued
      Re: Front sway bar end links failure
      Last time I heard a problem with them was awhile ago. When it was serviced by Honda they apparently tightened them.
      Yer the nut it's striped on the bolt. Even with the alankey it doesn't tighten nor losen.. So once the new ones arrive ill be getting the ginger out.. Hehe
        fkn honda? i just did a clutch on a Jazz serviced "by Honda" - a few bolts should not have been left on the car... grrrrrr
