Honda Integra Type S Brembo Brakes
    Hey there guys I was just wondering if I bought JDM DC5R Type r brembo brakes what would I need to get it running in my type s
    I think the simplest way would be to use the S2000 front rotors. Once you switch to those rotors the JDM DC5R brembos simply bolt on. I was using this setup on my car for 3 years without any issues.
    Edit - This is only for the front calipers.
      Yeah were you just using stock s2000 rotors or aftermarket slotted/drilled??
        As in direct replacement rotors made for the S2000.
          I think it doesn't really matter which rotors you use, stock or slotted/drilled. The measurements would be the same, I assume. I was using rda blank rotors then swapped to project mu slotted rotors.
