If you didn’t prepare your car for winter in autumn, there are a few products available to help you keep your car clean and protected.
Autumn is the best time to inspect and prepare your car for winter with a coat of protection, your car paint, tires, leather and rubber trim all need touching up and luckily Australia winter is never too extreme, blanket over your car finish this winter for protection is not too late
![](https://de1carcareproducts.com.au/images/thumbnails/280/280/detailed/1/DSC_0036.JPG)
Shampoo with wax - wax added shampoo is for colder climates, where a small bit of protection will be added during the car wash and to extend the life of your favourite liquid or paste wax products. Super Slick & Wax will gently lift the dirt and grime away with lubricants, emulsifiers, and wax
![](https://de1carcareproducts.com.au/images/thumbnails/280/280/detailed/1/DSC_0022.JPG)
Paint sealant - your car is more likely to be scratched during winter from road elements and the best protective coating is paint sealant whether your car is outdoor or exposed to extreme winter conditions, the polymers in sealant will seal against water, moisture, road salt and chemical penetration
![](https://de1carcareproducts.com.au/images/thumbnails/280/280/detailed/1/DSC_0001.JPG)
Natural looks, trim restorer and leather staff - winter is also harsh on rubber and leather trims, cold and dry air will draw moisture away from trims although I may still look good but a conditioning will prevent it from becoming too brittle
![](https://de1carcareproducts.com.au/images/thumbnails/280/280/detailed/1/DSC_0009a.JPG)
Tire dressing - your car’s tires will have a tough job in winter too, a quality tire dressing will keep tires moist, look good and to prevent the rubber from deteriorate
![](https://de1carcareproducts.com.au/images/thumbnails/280/280/detailed/1/DSC_0045.JPG)
Wheel protection – Delicate wheels need to be cleaned and protected in winter too against environment and make wheel easy to clean
Use Promotional code "ITRSALE" to get 10% off total value
Happy Detailing...
Happy Detailing...
